load factors on lifting
Anyone knows load factors in lifting?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
load factors on liftingload factors on lifting(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: load factors on lifting
That's like "lifting" oneself--does that count?
Stuck inside doing a project however. I'm comically behind.
<== can barely life my arms to type
These fellows are having a bit of fun at your expense, but seriously, just make your question more specific and someone will probably be able to help you. As to 271828, if he didn't spend so much time on this site, maybe he wouldn't be so comically behind.
nsjxs, I'd second hokie66 - It's Saturday and we're just relaxing a bit - just post more details about your question and I'm sure we'll all tackle it.
The point is well taken, though.
My problem is one of over-commitment. I just can't say no. Dissertation proposal, then consulting work, then writing papers, conferences, committee work, etc. I actually said no to a really interesting project yesterday and was very proud of myself!
271828 comes from my little girl. Her name starts with E, so I called her "Little E" which morphed into e, which is of course the base of the natural log. I couldn't use a handle with a decimal point, hence the name.
You're a daddy. Be sure to give little "e" a hug tonight and read her a story!
I got an answer from JStephen. Thanks.
JAE and 271828, it doesn't hurt to have some fun now and then, IMHO.
-Mike
just thinking about how factor of safety in lifting should be considered.
3 is usualy considered by most engineers and maybe this is because of the following:
-uncertainty of load would be a factor of 1.6
-dynamic factor of 1.25
-and a factor again of 1.5 which I think this includes material strength reduction
Im not certain of how the 3 is got but if someone got answers i'll be very thankful
sorry for my choice of words. its just that I'm not really good in english. And I'm also a young engineer so I havent got enough experience yet.
It's been a long time since I read thru the AISC material on lifting beams so I can't really remember the reasoning behind their recommendations. My first job after my engineering degree was in a plant engineering department where one of my responsibilities was lifting devices. I started using the 1/3 factor simply because that was the way they did it. Later after doing more research I added the 1/5 factor of safety. I think the 1/5 is useful to prevent the use of materials not ductile enough to go into a gradual yielding when overloaded.
One cause of impact is the result of the lifting speed of hoists which can be determined using several of the crane specs. You could check the following site for either the CMAA#70 spec or the Monorail spec.
http://www.mhiastore.org/category.cfm?Category=16
-Mike
1/2% for each foot/minute of the working load, not to be taken less than 15% or more than 50%.
Do a search for MH27.1-2003 which is the monorail spec.
If you multiply the three factors you mentioned in your post of May 20, you get 3.
Lcubed
A shipyard gantry lifting 1000 ts or a crane in a marina to lift dinghies? I would recommend you to have a look in the Codes for lifting appliances used by Lloyd's or DNV or any other national design codes.
