SelectionChange
SelectionChange
SelectionChange
I've made the following to autofit the row of the cell I selected, but I want it to be the origin row height after another cell is selected.
Private Sub Worksheet_SelectionChange(ByVal Target As Range)
    Target.EntireRow.AutoFit
End Sub
RE: SelectionChange
Hi Robert:
Is Origin a fixed range, such as cell C3? ... if so then let us try ...
CODE
    Set Origin = Range("C3")
    Origin.EntireRow.AutoFit
End Sub
Yogi Anand, D.Eng, P.E.
Energy Efficient Building Network LLC
ANAND Enterprises LLC
http://www.energyefficientbuild.com
RE: SelectionChange
Sorry, I did not describe it clearly.
Like this:
I select C3, the 3rd row becames autofit, I can read the whole data in this row.
And then, I select D4, then the 3rd row will be back to its origin height, like 12.75, and the 4th row becames autofit.....
RE: SelectionChange
You mean like:
CODE
Dim OldHt As Double
Dim NewHt As Double
Dim OldSel As Range
If (Target.Row <> OldSel.Row) And (Target.Rows.Count = 1) Then
    If Not OldSel Is Nothing Then
        OldSel.RowHeight = OldHt
    End If
    Set OldSel = Target
    OldHt = Target.EntireRow.Height
End If
End Sub
RE: SelectionChange
Thanks, handleman
As I run your codes, it says "Object variable or With block variable not set", it may points to OldSel.
I've tryed this kind of method before, set Oldsel as Target at end of program.
RE: SelectionChange
I've got it solved:
Public ff, tt
On Error Resume Next
Rows(ff).RowHeight = tt
ff = Target.Row
tt = Target.RowHeight
End Sub
