pressure load and abaqus viewer
Hi everybody,
I need to know if it is possibile to show pressure loads applied on solid or shell element once the run is completed. I mean, I wrote the input file directly through a text editor. The model is based on solid element (C3D8) and I've applied a pressure load on the faces of some element. I need to verify that the pressure load direction is correct. Is it possibile to show pressure load direction (as for example I can do with imposed displacement) with abaqus viewer, opnening the odb file once the analyses is finished? Thanks
RE: pressure load and abaqus viewer
corus
