Galvanized vs. galvannealed
Is there any difference in corrosion protection for steel sheet hot-dip galvanized (zinc coated) vs. the heat-treated or "galvannealed" material that produces a zinc/Fe alloy at the surface?  The environment is indoor and possibly outdoor on commercial buildings.
RE: Galvanized vs. galvannealed
As long as they both have roughly equivalent thickness and zinc content, then there won't be much of a difference in the environments you describe.
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
Galvannealed used to be a trademark (Keystone wire?), but not any longer.
Functionally there is no difference that I have ever seen.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
