Noise Calculations for Pipe Flow
Can you direct me to some noise calculations regarding fluid flow in small pipes?
Specifically, I have 4" Nominal Pipe. The different fluids I am looking at are Water, CO2, and a production stream comprised of water/oil/gas.
Thanks for the help!
RE: Noise Calculations for Pipe Flow
Pete
P. J. (Pete) Chandler, PE
Principal Engineer
Mechanical, Piping, Thermal, Hydraulics
Processes Unlimited International, Inc.
Bakersfield, California USA
Best Regards
Morten
This is an extensive written guide and accompanying excel spreadsheet that covers all areas of gas flow noise estimation. It USED TO BE available online at NASA Glenn Research Center, but was removed after 9/11/01.
http://www.grc.nasa.gov/WWW/AcousticalTest/HearingConservation/QuietByDesign.htm
Best Regards
Morten
Try google before anything else
