Flow meter?
Flow meter?
How factored and unfactored scale affects flow rate? Flow meter specifies 2ms for unfactored, does it mean that it coincides with the rated flow rate?
Thanks.
"Whenever you are asked if you can do a job, tell them, certainly I can! Then get busy and find out how to do it." Theodore Roosevelt.
RE: Flow meter?
RE: Flow meter?
RE: Flow meter?
RE: Flow meter?
I'm hesistant and getting lose to think the relationship of unfactored scale of having a 2 msec pulse with the flow rate.
Some rather say that this unfactored pulse, or factored pulse relates to flow rate resolution?
"..the more, the merrier" Genghis Khan
