Water heating theory question
Hi all,
I have a water heating theory question that is hurting my head a bit.
Scenario:
1. Say I have two water storage tanks - one of 10L one of 5L.
2. The tanks have a secondary sealed surround - filled with PUF insulation so the only method of cooling is via conduction (rough assumption but go with it for the question).
3. Both tanks are to be maintained using a heating element cutting in at 93degC and out at 96degC.
I know by Q = m*Cp*deltaT that the energy into the 10L tank is double that into the 5L tank. The 10L and 5L tanks roughly transfer HEAT at the same rate by their design - so Q'1 = Q'2.
So the 5L tank cools twice as fast as the 10L one because it has half the stored energy Q' = Q/deltaT.
Essentially it seems that the more efficient option is to heat a 10L tank as it takes the same amount of energy to keep 5L at 94.5degC as it does a 10L tank?
(I know that the intial heating of the tanks to 94.5 will take more energy in the 10L but thereafter the energy in to the tanks is common)
Any assistance to my Friday brain would be appreciated.
James
Scenario:
James
RE: Water heating theory question
Assume PERFECT insulation. You put energy in once to heat of the water in the tank, then the only future energy needed is for heating the make-up water that replaces water used.
So in the perfect insulation case, efficiency is directly m*Cp*Dt/Input.
If you consider losses from the tank:
efficiency = ((m*Cp*Dt)-losses)/Input
If you go with your assumption the losses from both tanks are the same, then there is no difference in efficiency (at steady state).
If you consider the initial heat-up, then the larger tank is more efficient because m is larger.
Thanks!
If the 10 liter is a sphere container and the 5 liter a veseel with a 7.5 lenght/diameter tank, the 5 liter will lose heat faster!
