activation home laptop
Ok, I have a question about the activation of a Solidworks 2007 SP3.1 on a laptop that is used only when I am away from my Desktop. I know it is in the Solidworks Guidelines that I can use Solidworks on a portable device as long as my main computer is used more than 80% of the time. My company has 3 seats of Solidwork and they are all installed on a desktop. Today I updated all of our computers to SP3.1 and I got to my laptop. When I try to activate it I make sure I chose "Home" as it's place of use. But, it says that the 3 seats are already installed. I have searched Solidworks webpage and I can't find any answers. Can anyone help me?
RE: activation home laptop
You need to check out who has what serial numbers and then if you have to transfer the license back to SW and start over with Licenses... that doesn't require to to reinstall. But if your colleagues are using your serial number then it will require them to change their installation of SW (see control panel\Change after you select Solidworks)
Scott Baugh, CSWP![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
www.scottjbaugh.com
