24 volt ethernet hub
Hello all,
I am installing a Controllogix device and using a Red Lion display for the HMI. I figured out how to get the ethernet working between the two. I am looking for a ethernet hub that operates off of 24 volts and haven't found anything on the net.
Any suggestions are welcome.
RE: 24 volt ethernet hub
http://www.n-tron.com/
Or you can try B&B Electronics, they also make a very good industrial ENet hub and switch.
http:
Sometimes I only open my mouth to swap feet...
Take a look at www.bb-elec.com
http://hus.hirschmann.com/English/
I would also suggest using a switch rather than a hub.
http://www.phoenixcontact.com/
xnuke
"Live and act within the limit of your knowledge and keep expanding it to the limit of your life." Ayn Rand, Atlas Shrugged.
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
What we need is an industrial grade/ruggedized switch with management capabilities, and that can handle trunking VLANs.
Cisco makes the 2955 series switch, which is a 12 port fully manageable, Din rail mounted unit. It is their “industrial” offering. It works well, we have several in operation, but it is bulky, and only runs off 24VDC. Many other industrial switches have the standard 10-30 VDC range on the input power.
Does anyone know of a good managed switch for the industrial arena?
Try this link,
They have the best Industrial managed switches available.
Take a look at Westermo's R200 and U200 switches on my previous link. I believe both have VLAN capability.
