Perforated pipe for exhaust systems
I am fairly new to the forum, and have a question in regards to perforated pipe.  My boss wants me to look into a machine that does the perforating, and apparently, there is only one company that makes them (engineers myth?).  All I know is that they are in New Zealand, and the machines are 60,000 ish (Can $).  If anyone can direct me to this company or other ones similar, please do so, perf pipe manufacturing info/ links would also be appreciated.  Thanks!!!
RE: Perforated pipe for exhaust systems
You need to subscribe to the Tube & Pipe Journal:
http://www.fma-communications.com/TPJ/TPJ.cfm
... and probably a dozen other trade journals, too.  Snag the subscription cards from the ones your boss gets.
There are specialized multiple punch piercing presses that are used to perforate sheet that is then rolled into pipe or tube.  Is that what you want?
Mike Halloran
Pembroke Pines, FL, USA
Thanks for the info Mike.
This machine will actually take welded pipe/D.O.M. pipe and feed it while making the perforation pitch.  So its pretty fancy stuff I guess you could say.  I almost "googled" my brains out trying to find this company.
Ciao.
Reference:  Sanderson Tube Louvre Technology (New Zealand)
            www.sandersonmachines.com
Thanks Wicsteve!  You do not know how long I have been looking for that site.
