2004 & 2006 CEPCI composite and sub-indexes
I have the 2004 composite index and the 2006 Aug composite and sub-indexes, but I need the sub-indexes from 2004 as well as the most recent final composite and sub-indexes, whether that is 2006 yr end or a few months into 2007.
Can anyone help?
I have downloaded CEIRev3.xls from curryhydrocarbons.ca, thanks owg!
I am also interested in the current weighting of the components? I have:
Equip. - 61%
Const. Labor - 22%
Buildings - 7%
Engineering - 10%
I believe these were updated sometime around 2002.
Thanks for any help.
Can anyone help?
Equip. - 61%
Const. Labor - 22%
Buildings - 7%
Engineering - 10%
RE: 2004 & 2006 CEPCI composite and sub-indexes
CEPCI Dec '04 Final
CE Index 464.4
Heat exchangers and tanks 516.8
Process machinery 513.2
Pipe valves and fittings 608.9
Process instruments 379.9
Pumps and compressors 727.2
Electrical equipment 360.8
Structural support and misc. 584.6
Construction labor 305.2
Buildings 438.6
Engineering and supervision 344.9
HAZOP at www.curryhydrocarbons.ca
CE Index, 478.7
Equipment, 558.9
Heat exchnagers and tanks, 523.9
Process machinery, 533.5
Pipes, valves & fittings, 655.9
Process instruments, 388.5
Pumps & compressors, 766.2
Electrical equipment, 385.3
Structural supports & misc, 598.4
Construction labour, 304.5
Buildings, 459.8
Engineering & supervision, 346.6
CE Index, 1.0
Equipment, 0.50675 of CE Index
Heat exchangers and tanks, 0.338 of Equipment
Process machinery, 0.128 of Equipment
Pipes, valves & fittings, 0.190 of Equipment
Process instruments, 0.105 of Equipment
Pumps & compressors, 0.064 of Equipment
Electrical equipment, 0.070 of Equipment
Structural supports & misc, 0.105 of Equipment
Construction labour, 0.290 of CE Index
Buildings, 0.04575 of CE Index
Engineering & supervision, 0.1575 of CE Index
owg - The spreadsheet CEIRev3.xls lists the 2004 index as 444.2, while in your post above, the Dec '04 final is 464.4. Is there a difference in the Dec final versus the 2004 final composite?
dbuzz - The breakdown you gave me was exactly what I was looking for except that I applied it to owg's Dec '04 values or your Jan '06 values, it doesn't fit. Any ideas or am I missing something?
Thanks again for all your help.
Great observation regarding the discrepency in the breakdown; perhaps there's been another update since 2000. I'll see what I can find.
What I am really looking for is the sub-indices and composite for the year 2004 and then the most recent set to date, 2007.
I have a project that was initially scoped out in 2004 by someone else and the forecast estimate established. So I am trying to bring those capital dollars in 2004 up to date with today's dollars.
CE Index, 442.6
Equipment, 505.8
Heat exchangers and tanks, 460.0
Process machinery, 490.4
Pipes, valves & fittings, 600.7
Process instruments, 377.9
Pumps & compressors, 714.9
Electrical equipment, 351.8
Structural supports & misc, 531.6
Construction labour, 306.1
Buildings, 431.5
Engineering & supervision, 345.6
The last update article I have is from CE Jan 2002. In that article the author states "Each annual index is the arithmetic mean of the monthly indexes."
