Freeware Converter of Shape Files to .dwg
All,
I have some GIS data that is in .shp/.shx formats.  I am using AutoCAD LT 2006 and I am not able to open/import shape files.  Is there a freeware package out there that will convert .shp/.shx to .dwg/.dxf?
Rich.....viking
Richard Nornhold, PE
RE: Freeware Converter of Shape Files to .dwg
You can try GRASS.  If it's good enough for the USACE then it should do dwg and shp files. http://grass.itc.it/
You can do this with the SHP2BLK Express Tool. I am not sure if it will work in  LT.
http://mechcad-insider.blogspot.com/
"The fear of the Lord is the beginning of wisdom"
