SendObject
SendObject
I have a Access 2000 DBase that I'm trying to use the SendObject method, with Lotus notes 5.0.3. Whatever I try, the report is attached as a ".tmp" file. This file can not be viewed or launched. I think the code is correct, because when I change a few lines and do a OutputTo, the file is available.
Is this a Lotus notes issue??
PLEASE HELP!!!
I can post the code if it makes it easier.
Cheers.
PLEASE HELP!!!
Cheers.
