Threaded Screws
Threaded Screws
Does anyone know the pros and cons of fine threaded screws to course threaded?
RE: Threaded Screws
RE: Threaded Screws
Coarse Threads vs. Fine Threads
Coarse Threads:
For most applications, course threads offer these advantages:
Easier and faster assembly, providing a better start with less chance of cross threading.
Nicks and burrs from handling are less liable to affect assembly.
They are less likely to seize in temperature applications and in joints where corrosion will form.
Less prone to strip when threaded into lower strength metals.
More easily tapped in brittle materials and or materials that crumble easily.
Fine Threads:
Fine threads may make for a superior fastener for applications with specific strength or other requirements.
They are about 10% stronger that coarse threads due to their greater cross-section area.
In very hard materials, fine threads are easier to tap.
They can be adjusted more precisely because of their smaller helix angle.
Where length of engagement is limited, they provide greater strength.
Thinner wall thickness can be used because of their smaller thread cross section.
Heckler
Sr. Mechanical Engineer
SWx 2007 SP 3.0 & Pro/E 2001
XP Pro SP2.0 P4 3.6 GHz, 1GB RAM
NVIDIA Quadro FX 1400
o
_`\(,_
(_)/ (_)
(In reference to David Beckham) "He can't kick with his left foot, he can't tackle, he can't head the ball and he doesn't score many goals. Apart from that, he's all right." -- George Best
RE: Threaded Screws
Don
Kansas City
