Correlation of dew point of dry air
I have a plant with a quoted ideal loading of 50mg/Nm3 of moisture in air post a drying tower. Any idea what this is in terms of the air dew point?
Correlation of dew point of dry airCorrelation of dew point of dry air(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: Correlation of dew point of dry air
Tranform it into a mol fraction. Multiply by the total pressure to get the moisture's partial pressure. Look for temperatures in tables of water/ice vapor pressures. I may be wrong, but my estimates for atmospheric conditions indicate a dew point of about -57oC.
However, this link Dew Point says something else.
It all depends on what is "standard" or "normal" air.
Normal: The density of dry air at 0oC and 1 ata is 1.3 kg/m3, thus, the mass concentration would be:
Standard: Dry air at 70oF and 101.325 kPa has a density of 1.2 kg/m3 resulting in a mass concentration of
Quark, sorry I wrongly read the vapor pressure table, and your finding is right. Then,
4.17*10-5 mass basis *29/18 → 67.2 ppm by vol, corresponding to a dew point of ~ -50F or ~ -46oC in the given link.
I assumed 29 and 18 for the MW of air and water, respectively.
Cheers
Trevor
