EVEN AND ODD NUMBER PROGRAMMING
I'm trying to program a line where I have a number and when this number is a even or odd number, the program changes. I'm looking for the fonction that will allow the program to change the pattern if x=2, 4, 6, 8, 10..... and will allow to change it again if x=1, 3, 5, 7, 9......
Like, I have
IF x 'fonction for even number'
    pattern_1=2
else
    pattern_1=3
endif
thanks
RE: EVEN AND ODD NUMBER PROGRAMMING
I think the function you are looking for is "integer division"
Integer division is division in which the fractional part (remainder) is discarded is called integer division and is sometimes denoted "\". Integer division can be defined as , where "/" denotes normal division and  is the floor function. For example,
    10 / 3 = 3 + .33333
so
     10 \ 3 = 3
Then you must compare the two statements like this
if (10/3)-(10\3) <> 0
 then
 else
endif
Unfortunately, ProE does not have the "integer division" implemented, but you can simulate it using "floor" function:
if (10/3)-floor(10/3) <> 0 .....
-Hora
I'm not sure if this is gonna work for what I want to do.
I have a pattern of prt0001 and a pattern of prt0002 and I want that when the pattern of prt0001 is a even number that the pattern of prt0002 is equal to the pattern of prt0001 divided by 2 but when the pattern of prt0001 is a odd number, I want the pattern of prt0002 to be equal to the pattern of prt0001 divided by 2 + 1
IF PATTERN_PRT0001=EVEN NUMBER
      PATTERN_PRT0002=PATTERN_PRT0001/2
ELSE
      IF PATTERN_PRT0001=ODD NUMBER
            PATTERN_PRT0002=(PATTERN_PRT0001/2)+1
      ENDIF
ENDIF
THANKS
OK, I understand, then is very simple:
if ((-1)^PATTERN_PRT0001 == 1)
then
else
endif
because:
(-1)^even number = +1 and (-1)^odd number = -1
That's all. Good luck
-Hora
