How do I use the deform function?
Hi, I hope you can help!!
I'm having real difficulty using the deform function in solidworks? I think thats the function I need. I'm trying to create cutting teeth (similar to a cheese grater) on a sphere. How do I use my own tool to deform something?
RE: How do I use the deform function?
Scott Baugh, CSWP![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
www.scottjbaugh.com
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all. And awe transcends reason.
Can you post images of what you are trying to achieve?
FAQ559-1100: How Can I Show An Image In A Post
If you have the "cheese grater tooth" as a separate model, you may be able to use it as a tool for the Indent function ... or with the Combine function.
Jeff Mowry
I'm not sure if I should put up a picture but I'm basically trying to put cutting teeth on a hemisphere where the cutting teeth are on the inside. Not sure if that makes it a bit clearer.
