Solar Panel Mega Mystery (need a sherlock!)
Greetings, I just replaced a 120W panel with a new 130W panel via a warranty. 130W was all the manufacturer had. When I hooked the system back up, my charge controller read 0.00. The second I removed the new panel, it went back up to normal of around 20.3. That is the mystery. Here are some facts.
The solar system is 24V. The 120 and 130W panels are 12V wired in series. I get plenty of voltage at the junction box on the back of each panel, and I get a bit more down at the junction box where the panels are linked to the other panels in the array so I know I don’t have a break in the line somewhere.
I double checked the run of the wiring, and all is as it should be based on the manufacturers recommendations and how the system was set up previously.
Obviously you need more information to help me troubleshoot this, so what is it that you need to know?
The system is NOT grid tied, and powers my cabin.
Thanks for all your help. - Shane
RE: Solar Panel Mega Mystery (need a sherlock!)
Keith Cress
Best regards
Dr Watson
Gunnar Englund
www.gke.org
respectfully
AT any rate, it is easy enough to test. :)
If you dont hear from me, call the wife... I am out below the array being zapped by green energy. :)
Defective units DO get shipped in new boxes.
This would be my second check.
respectfully
Keith Cress
Gunnar Englund
www.gke.org
How does one distroy a panel anyways? For example what would hapen if I reversed the wires in teh compiner box? Pos to neg and then neg to pos? Can that be tested or if there is juice running through the system, will I fry something?
Thanks so much for all you advice, this forum is great. :)
