Volume of a Box = LWH
I know this is simple, but I have been in Shanghai for two weeks and I am burnt out.
If it is given that a box size is 25 liters and I need to control the L,W, & H what is the best way to set up the expresions.
I want to be able to change any one of the 3 and the other two would update.
Sorry for the simple question.
RE: Volume of a Box = LWH
For example, if you start out with all sides being equal, a 25 liter 'block' would have each side equal to 29.24 mm. Now if I change the size of one side, which one of the others sides do I change? Or do I change them both?
So you see, it've not a trivial, nor even a straightforward problem to solve.
John R. Baker, P.E.
Product 'Evangelist'
UGS NX Product Line
SIEMENS
UGS PLM Software
Cypress, CA
http://www.siemens.com/ugs
Once before I had to base the weight of a block used in a toque gage based on a supplied value so a wrote a relation for the Xsec Area and used that to drive the block thickness base on the supplied Parameter for it's weight.
Michael
using the Expression system of NX, couldn't you subordinate the update to a "switch" which indicates which dimension has to drive the others?
Example:
switch=1 (1 = length and width are independent; 2 = width and height are independent; 3 = height and width are independent)
IF switch =1 then ...
IF switch = 2 then...
IF switch =3 then...
