Small filter for hot water (10 micron)
3-4 GPM max 10 micron filter for water up to 180 deg F.
It is insane what some of these companies are asking- mostly hot tub companies with 10 inch cartridge filters. Way larger than necessary. This is just a filter to keep stuff out of a positive displacement (gear motor) pump. It's recirculating water into a closed tank.
Any clue as to where to look for these filters? I belive HPLC uses these small high temp filters but I can't find them.
