translating assy
translating assy
I try and translate and assy to a step, iges, parasolid from SE. Then i try to open it in SE(same version) The file opens and i see the "bodyfeature_1" in the feature manager, but there is no actual models showing. I've tried turning on everything. Still nothing. Any ideas.
THANKS!
THANKS!
Solidworks 2005
Solid Edge V17
RE: translating assy
What options do you have checked?
Are you creating an import log? If so, open the text file and verify that the import was successful.
The "bodyfeature_1" usually means that the import managed to resolve a water tight solid body. I'm can't quite fathom why it wouldn't show in the graphics area. Just to verify the obvious, zoom to fit?
--Scott
http://wertel.eng.pro
