Bulk modulus of LPG
Bulk modulus of LPG
I am looking for the bulk modulus of butane and propane to perform a water hammer analysis. Any idea? After searching in Internet, Perry's, etc I have found nothing...
Thank you.
Thank you.
RE: Bulk modulus of LPG
http://www
http://www
http:/
David Baird
Sr Controls Designer
EET degree.
Journeyman Electrician.
which are,
Propane 2000-2500 fps
Isobutane 2200-2800 fps
N-butane 3100-3700 fps
at 68ºF and 200 psiA
http://virtualpipeline.spaces.msn.com
I was going to give you the same advice that BigInch gave you. The NIST webbook gives you sound velocities c [m/s], and the liquid densities ρ [kg/m3], at the conditions you wish.
Using metric units, the bulk modulus Y [kg/m2] is estimated from:
BigInch: Modestia aparte !
