Spray Model
Spray Model
Does anyone have any tricks up their sleeve that could help me model a fluid spray stream?
I need to get a pretty picture of fuel spraying out of a fuel injector. Any tips would be greatly 'preciated.
RE: Spray Model
1. Make a feature that represents the spray pattern, such as a cone.
2. Make it transparent or semitransparent and play with its color to get close to what you want.
3. Select the surface of this feature and pick a texture to simluate the droplets.
You should be able to do this as a feature of a part, or you might want to model it as its own part and use it in an assembly with the injector.
- - -Updraft.
RE: Spray Model
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all. And awe transcends reason.
RE: Spray Model
I was more curious if anyone had a fast way to make a more non-uniform spray of globs and squirts (engineering terms);)
Dan
www.eltronresearch.com
RE: Spray Model
Scott Baugh, CSWP![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
www.scottjbaugh.com
RE: Spray Model
Jeff Mowry
RE: Spray Model
Dan
