Wire voltage rating
Wire voltage rating
Given a low voltage cable rated at 600VAC, what would be the maximum allowable DC voltage on which the cable could operate and remain within its design withstand, 600VDC or 850VDC? My question comes from a VFD commom bus application where two drive DC buses are interconnected. A 480VAC VF drive has a dc bus voltage of apx. 680 volts. Must the bus connections be linked with 1000 Volt rated cable or can the 600 volt cable be used under existing codes in the US?
RE: Wire voltage rating
And heating has effect on maximum currents, not voltage.
