Pressure loss through electric heater
sir,
I am trying to calculate pressure loss through rectangular vertical electric heater. air is flowing through heater is 1000 SCFM and temerature increase is from 80 F to 1600
if any one have any formula to calculate pressure drop in this condition. please help me....
Thank you
RE: Pressure loss through electric heater
Is delta t 1520 deg F ??
I did not see your other post until after I had submiited response
You can try posting in the 'HVAC/R Enginnering' forum
yes sir DT is 1520 F
just a plain ol pressure drop calculation will work.  Just break the exchanger up into small pieces with an average temperature of each section to get velocity in that section and from velocity you get pressure drop.
can one give me formula for that or can you tell me where i can find ..
