Access SW- properties with VB ?
How does one access the many "SW-" standard properties within VB. I understand how to access the custom properties, but these are a puzzle to me. Just a read access would be sufficient.
(For example the "SW-File Name" property that can be used in a note.)
RE: Access SW- properties with VB ?
Have you checked the SW API help? That will show you some code for what your looking for, and if that doesn't give you what you need. Try making a macro of what your doing and edit it to find the API code.
I hope that helps,
Scott Baugh, CSWP
credence69@REMOVEhotmail.com
http://members.sigecom.net/sbaugh/
