Solidworks Material Properties
What are the default SW properties for Materials in SW. Or where can you find a list?
Also, can you add a new property field for the materials. For example, a commment field specificying where you got the material properties, for reference. For example, you may get some properties from MatWeb and other properties may come from the part supplier.
-Robert
-Robert
RE: Solidworks Material Properties
Chris
SolidWorks 07 3.0/PDMWorks 07
AutoCAD 06
ctopher's home (updated 04-21-07)
Also, I sent an email to you yesterday. Did you get a chance to look at it?
Macduff![[spin] spin](https://www.tipmaster.com/images/spin.gif)
Colin Fitzpatrick
Mechanical Design Engineer
Solidworks 2007 SP 2.2
Dell 390 XP Pro SP 2
nVida Quadro FX 3450/4000
We have multiple people adding materials to a SW materials DB. Over time, it will be difficult to know the source fo the material properties. The properties could come from a variety of sources depending on the material(specific or general). After a material is entered, there may come a day when someone questions the value for a property. With no reference, there is no information to back up the claim that the property value is correct.
I heard that you could possible add a "Comment" field by editing SW material xml schema definition file(sldmaterials.xsd). Anyone have experience w/this?
-Robert
I have not forgot about it.
I responded to your email this morning.
Robert,
I have not looked into adding comments.
I had an experience mechainal engineer and 3 major aerospace firms check my database. IMO, when someone creates a material, anyone can say they got the info from a reliable source. My suggestion is to have a reliable engineer check the work.
Chris
AutoCAD 06
