Linking Question
Linking Question
Linking Question
Hi all.
Created a new standard of callouts - -
Does anyone know of a way to link the callout format text file with my new standard to the Hole Wizard?
Thee Ox...thanks you.....and has left the building.
RE: Linking Question
I believe you have to add callouts to the text file with your new Standards DB. If you look at the text file it has each of the standards in it. Try adding your DB to the text file and test it out using a special callout.
Scott Baugh, CSWP pc2
www.scottjbaugh.com
How did you create the callout file?
AFAIK, the calloutformat.txt is linked to the HW, so naming the new callout file that should do the trick.
Make a copy of the original first though.
cheers
Thanks to all!
Doint the calloutformat.txt thing did the trick.
Thanks again....
Yer pal,
Thee  ;)
