power pole spacing
power pole spacing
I need to provide primary service from an end of the line pole to a new building 170 feet away. Could I do this with one pole? It is 13KV with 2/0 cable. What is the governing code for this?
RE: power pole spacing
I suspect 170 ft span is possible, but it will require some design work by someone with some experience in overhead line design.
_____________________________________
I have been called "A storehouse of worthless information" many times.
