Simple RTD filtering circuit
I have a noisy RTD input to a control network and suspect the analog input module. Problem is, I can't rule out the wiring between the RTD and the module. Is there an easy low pass filter capacitor or something that I can try to use to rule out the noise coming from the wiring?
RE: Simple RTD filtering circuit
Sometimes I only open my mouth to swap feet...
Keith Cress
