Request for advice regarding minimum bushing clearance & material
Hi everyone,
I would like to ask if anyone could please offer some advice on the following...
I have a cantilever mounted round steel housing about 1.5" long that I want to oscillate on a 3/8" OD hardened steel dowel pin. I plan on just pressing a bushing material into the full length of the housing, and then drill & ream the bushing ID to fit over the dowel pin. I need the clearance between the ID of the bushing and the OD of the dowel pin to be as small as possible. I can only lube the bushing once at
assembly and then never again.
I would prefer that the maximum clearance between the dowel pin OD and the bushing ID is not over .001" but I may be able to get away with .002". I would like to use a high pressure grease to lube the bushing and shaft, but how small can my clearance be before it won't allow the grease to go and/or stay between the shaft OD and the bushing ID, or
before the low clearance defeats the lube somehow ?
The housing is just oscillated by hand intermittently. Any
recommendations for a bushing material, bushing ID surface finish, and lube, would be appreciated.
Presently, I have no choice but to press some bushing material into an existing housing, but in the future, would I be better off making the housing itself out of some pre-hardened 4140 and then using the housing itself as the bushing material ? Would this wear much better than a bronze bushing ? Would non-hardened 4140 or non-hardened tool
steel wear better than bronze ?
I would like this thing to last as long as possible before the clearance opens up too far. I also think I need to stay with a bushing and not a rolling element bearing.
Any advice or personal experience with bushing materials, loads, and estimated wear rates would be appreciated.
John
John
RE: Request for advice regarding minimum bushing clearance & material
http://www.neelyindustries.com/pdf/77.pdf
Here is one alternate (C-Flex) to facilitate Oscillating motion you might want to explore.
http://www.c-flex.com/companyproducts.pdf
Here are two approaches to the type bushing you are attempting to make. These are standard off the shelf items.
They are easily replaceable.
http://w
http://www.connexusa.com/HTML/principle.html
I will check out the links you gave.
John
http://www.ggbearings.com/
Ted
http://www.afmusa.com/bushings.composite.asp
The DX versions are lead free and the DU bushings have a small percentage of lead which helps if you're running them dry. These bushing can be sized (peened) after installation to achieve the correct dimension.
Heckler
Sr. Mechanical Engineer
SWx 2007 SP 3.0 & Pro/E 2001
XP Pro SP2.0 P4 3.6 GHz, 1GB RAM
NVIDIA Quadro FX 1400
o
_`\(,_
(_)/ (_)
(In reference to David Beckham) "He can't kick with his left foot, he can't tackle, he can't head the ball and he doesn't score many goals. Apart from that, he's all right." -- George Best
I have used these quite a bit and they have perfomed well.
