Constant force simulator
I have an application where a ball screw and motor are lifting and lowereing a platten ~ 14 inches loaded with either 160 pounds or 250 pounds depending on the product model. I currently am using barbell weights to simulate the load that would normally be seen in the field in the form of a steel cover; the barbell weights are manually set on the platten by 2 people as we have a single man 40 pound lifting rule. Short of purchasing a bulky hoist, I would prefer to simulate the weight via sometype of dynamic mechanism that would allow for a selectable form (160, 250 lbs) of constant force over the 12 inches of travel as my test sequence cycles between upper and lower positions. Does anyone have any suggestions?
RE: Constant force simulator
Cheers
Greg Locock
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
Ted
Change the radius (notched position ?) of the counterweight location to get loads desired.
