Wet Weather Spring
Wet Weather Spring
Can anyone give me any information on 'Wet Weather Springs'? I am managing an apartment complex for an investment company, and the complex is suffering greatly from a hillside that stays continuously wet right now, and in the past. The water drain off is constant, not drying up and is affecting apartment building that are situated immediately below the hill. I contacted the city as the contractors that have came out keep stating that there has to be a main water break on that hill, but the city insists they have no breaks. The water is continuously coming from somewhere however.
I spoke with a lady today that mentioned the complex area used to be farming land (cattle) and was used for such because of the "Wet Water Springs" on the land that fed the ponds. I had never heard of such a thing and she could not explain it, just said she had heard of this spring on the property. The investment company has mentioned calling out an engineer to investigate where the water is coming from, and so I am seeking any information on this topic so that I can relay it to them. Missouri is known for its springs, but I have never heard of a "Wet Water Spring", and would appreciate any info anyone can give, what it is, how it operates, and if there are any fixes for such a thing.
Kris
Kris
RE: Wet Weather Spring
One way to verify if it is a watermain leak is to take a sample to a lab and have it analyzed and then compared to the city water sample (from your tap). It should be easy enough to determine if it is city water.
If it is a spring, then a geotechnical company will be able to design a system to collect/control the water to reduce the impact it is having on your property.
