Change default setting for dimension fonts
How or is there any way to change the default font setting for the dimension fonts.  It is always 13 and I want the font to be 10 I keep having to change every one of my font values.  Thanks!
RE: Change default setting for dimension fonts
It's under Tools->Options, Document Properties tab.
You should change the size in the document templates (prtdot, asmdot and  drwdot) for future use.
cheers
Ok I can change them in the options menu but it's not permenant.  How do you change them in the document templates?
Nevermind I figured it out thanks you guys!
