Moving parts in an assembly (Into another sub assembly)
I have a final assembly that is comprised of various parts and sub assemblies.
Now I have some "parts" that I have in the final assembly that I would like to group together and move into an existing sub assembly.
Can i do this?
Can i do this?
RE: Moving parts in an assembly (Into another sub assembly)
select the part to be moved and then use the Transfer function
which becomes actived then. You find it below the Replace
function on the toolbar
dy
