Definition Required -LCV
I am reviewing a document from an European vendor which depicts a value for 'LCV' relating to natural gas and combustion.
Please advise definition of 'LCV'
Thanks in advance for your cooperation and consideration
RE: Definition Required -LCV
LCV = low calorific value, aka NCV = net calorific value, aka LHV = low heating value.
I quote from Wikipedia:
Is the term 'LCV' commonly used in the USA??
I have previously seen/used the LHV term
STYMIEDPIPER:
No, the term LCV (low caloric value) is not commonly used in the USA. The commonly used terms in the USA are:
(1) LHV (lower heating value) or NHV (net heating value)
(2) HHV (higher heating value) or GHV (gross heating value)
where:
HHV - LHV = the heat of vaporization required to vaporize the water produced by the combustion of the fuel.
Milton Beychok
(Visit me at www.air-dispersion.com)
Thank you for the info
