How to set an axes Ylabel to vertical orientation?
Hi anyone,
    My application contains a graphic called ‘AxeSpot’. The trouble arises when I try to set the Ylabel. It appears horizontal and not vertical in spite of setting the ‘rotation’ property to ‘90’. To show the graphic I push a button. The button’s callback executes the following code:
% Get the main figure’s handle
hfmain=findobj('Tag','FigMain'); % Main Figure’s handle.
% Create the ‘AxeSpot’ axes (which is a main figure’s child) with certains properties.
h1 = axes('Parent',hfmain, ...
    'Units','pixels', ...
    'Position',[181 228 177 104], ...
    'Tag','AxeSpot', ...
    'Color',[1 1 1], ...
    'Layer','top', ...
     'Visible','on',...
     'XColor',[1 1 1], ...
     'YColor',[1 1 1]);
hspot=findobj('Tag','AxeSpot');     % This sentence asign a handle to ‘AxeSpot’ axes.
axes(hspot);                         % This sentence select ‘AxeSpot’ as current axes.
set(hspot,'NextPlot','add');          % This sentence add the nexplot to ‘AxeSpot’ axes.
spot(v_out);                          % This is the function that show the plot over the %‘AxeSpot’ axes.
% Xlabel
set(get(gca,'XLabel'),...
   'String','Altura',...
   'Color',[0 0 0.5], ...
   'HorizontalAlignment','center', ...
   'Visible','on',...
   'FontName','MS Sans Serif',...
   'Fontsize',6,...
   'FontWeight','normal',...
   'VerticalAlignment','top');
% Ylabel
set(get(gca,'YLabel'),...
   'Visible','on',...
   'Fontsize',6,...
   'Rotation',90,...
    Why does it not work? Do you know how to solve it?
    Thanks a lot,
      Cris
RE: How to set an axes Ylabel to vertical orientation?
The normal Ylabel orientation is 90 degrees. If you want to change it set rotation to zero.
Joe
BSTEX - Equation viewer for Matlab
http://www.geocities.com/bstex2001
