Data fill with time/date.
I want to generate a series of times and dates, incremented hourly. Say I put in the first cell, then drag teh doohicky down. It increments daily. If I put "5/1/2007 15:00" in the second cell, it alternates
5/1/2007 15:00
5/1/2007 14:00
5/1/2007 15:00
5/1/2007 14:00
How do I get it to fill like this:
5/1/2007 14:00
5/1/2007 15:00
5/1/2007 16:00?
5/1/2007 15:00
5/1/2007 14:00
5/1/2007 15:00
5/1/2007 14:00
5/1/2007 14:00
5/1/2007 15:00
5/1/2007 16:00?
"...students of traffic are beginning to realize the false economy of mechanically controlled traffic, and hand work by trained officers will again prevail." - Wm. Phelps Eno, ca. 1928
"I'm searching for the questions, so my answers will make sense." - Stephen Brust
RE: Data fill with time/date.
5/1/07 15:00
5/1/07 16:00
5/1/07 17:00
5/1/07 18:00
5/1/07 19:00
5/1/07 20:00
5/1/07 21:00
5/1/07 22:00
5/1/07 23:00
I think you're doing something wrong but I don't know wha. Plus your example has dates decremented, not incremented
in the first cell and copy it to the second, then change the 15:00 to 16:00 in the second cell and it should work
IF you need that to be more accurate, then the best thing to do is to use an index that cycles every 24 counts and divide that by 24 and add to the whole day count.
TTFN
Foloowing is a solution using EDIT|Fill|Series ...
CODE
5/1/2007 15:00
5/1/2007 16:00
5/1/2007 17:00
5/1/2007 18:00
5/1/2007 19:00
5/1/2007 20:00
5/1/2007 21:00
5/1/2007 22:00
5/1/2007 23:00
5/2/2007 0:00
CODE
2. I selected column A
3. I invoked EDIT|Fill|Series ...
a) then in Series_in box I selected the option Columns
b) in the Type box, I selected Date
c) in Step_size I keyd-in 0 1/24
d) in Stop_value I keyd-in 5/2/2007
e) in the Date_unit box I selected Day
4. Then I clicked OK
Yogi Anand, D.Eng, P.E.
Energy Efficient Building Network LLC
ANAND Enterprises LLC
http://www.energyefficientbuild.com
