Crashes on drawing a spring
Anyone else had this problem. Everytime I try to access the helix feature or edit feature in an existing spring the thing crashes with the runtime error R6025 Pure Virtual Function Call ?
RE: Crashes on drawing a spring
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all. And awe transcends reason.
Scott Baugh, CSWP![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
www.scottjbaugh.com
When creating a sketch in a new drawing, invoking the helix command crashes SW 2006.
1.) Close all Solidworks applications.
2.) Go to the Start menu - Run..
3.) Type in cmd (this will get you to the command prompt)
4.) Type in “regsvr32 msflxgrd.ocx” without the quotes.
5.) You should get a dialog saying that the above file was successful.
The Helix command should now work.
Lou Monaco
Great Lakes Engineering & Design
lmonaco@gledinc.com
www.gledinc.com
