Export STEP question
Hi all,
I'm new to this forum.
Anyone know how to export an assembly from NX to STEP whilst retaining the assembly structure.
IE. currently if I export a STEP file of a known assembly, all the children show up in a single level as unparameterized features. (no components and sub assys).
I think IGES also behaves the same way.
thanks
thanks
RE: Export STEP question
Make the assy the work part.
When you export step and you're prompted to pick objects just hit ok without selecting anyhting.
This should the select the assy as the item to export and create components.
I hope that's correct.
Mark Benson
Aerodynamic Model Designer
Ben Loosli
Sr IS Technologist
L-3 Communications
