Amateur looking for help!
Hi all,
I am trying to create an animation of a simple rack and pinion system.
I have discovered the tool for automatically creating spur/pinion gears but I'm having trouble with the rack. How can I draw a rack with teeth that match the pinion gear? Is there a tool for creating gear teeth upon a flat surface?
I have V19 and not much experience........
Cheers.
Cheers.
RE: Amateur looking for help!
one simple solution might be:
- model the base strip as protrusion lenghth x height x width
- on a side of this model one tooth at one end and protrude it
to the opposite side.
- use linear pattern to do the pattering of this tooth along
the base strip
dy
