welding a deformed pipe
hi all
i have some trouble with weldment along a contact perimeter between a deformed tube and a plane.
some one have any suggestion?
thanks in advance
here you can find an example: http ://rapidsh are.com/fi les/311163 52/weldmen t.zip.html
thanks in advance
RE: welding a deformed pipe
Secondly, I think the surface shape is too complex for SW to be able to place a weld bead.
You may have to sweep a profile around to simulate a bead.
now i'm trying to make a bead with sweep as you suggest me.
thx
