reversing induction motor
why would a capacitor start induction motor run within current rating in counter clockwise direction but overload in the clockwise direction? the centrifugal switch opens ok in both directions.
RE: reversing induction motor
would you explain what you mean by overloading? I think you mean a bigger current than motor's nominal current. An another question, how do you change the rotation direction of the motor? Finally, what is the nature of the motor's load? or it work idle?
Regards.
Azmi Demirel
azzmi@elk.itu.edu.tr
Welcome
I am handsome but married :-)
rajiv krishen
rk@ktind.com
1. 3-phase squirrel cage and wound rotor induction motors have their direction of rotation changed by changing sequence of phases ABC to ACB which is practically implemented by changing two feeder conductor terminations. Conductor 1 on terminal t1 would go to terminal t2 and conductor 2 from terminal t2 would go to terminal t1 in the motor terminal box or at the same motor feeder upstream, e.g. inside the motor starter.
2. Similarly, higher number of phases motors, e.g. four-phase ABCD must be changed to ADCB.
3. A single-phase motor change of rotation direction is more involved and may or may not be possible, if you do not have right conductor ends available in the terminal box.
4. Single-phase and two-phase motors, just like other motors, must have their shaft torque within their rating to start and run, as designed and without any alterations to their starting arrangements.
