Coating Release Properties with Polyethylene
We are investigating coatings/treatments that can be used on heated seal bars to join thin film plastics. Seal bar tempeatures 250-350F, seal face pressure 80-120 PSI. Heat seal bar materials are C1018, AISI 304, C4140 and Brass Alloys.
Desireable coating/treatment properties are wear resistance, excellent release from polyethylene, chemical resistance to caustic washdown solutions used in the Dairy and Meat Packaging industries.
What we have tried: PolyOnd (Nickel-Teflon), Nedox SF-2, Anodize Hardlube (Teflon treated), Electroless Nickel, Hard Chrome.
Other coating we have considered: SilverStone and Ceramics. The SilverStone (Teflon) though known to have excellent release with Poly is soft and easily removed. A bearing and shaft manufacturer has confirmed that Alumina and Chromium Ceramics do not hold up well in caustic washdown environments.
We do know that high temperature Teflon tape (Dupont Teflon coated onto a fiberglass cloth exhibits excellent release characteristics. Long term this is not a satisfactory solution.
RE: Coating Release Properties with Polyethylene
http://www.halechrome.com/nickel.html
http://
Here is a process(QPQ) that we used quite a bit in preventing hot polymer from wearing an sticking to guid bars
http://www.trutecind.com/heat/melon.htm
http://www.burlingtoneng.com/melonite.html
Here is one process used by our reasearch group to prevent sticking. This is a fairly elaborate and expensive process as it involes very high tmeperature.
http://www.tdcoating.com/index.php
