Hand Pump - odd question
I know this may be an odd question and unrelated to engineering, but I am looking for a hand pump (similar to a bicycle pump) that has both intake and outake ports. I want to hook up some hoses and pressurize a small vessel with something besides air (any type of gas). I have seen a pump like this before in a college lab but have had no luck locating one. Any suggestions? Perhaps someone knows where I could get a coupls small air valves and construct one myself? Any input would be great. Thanks.
RE: Hand Pump - odd question
You can make one from an air cylinder and a couple of soft-seated check valves, a tee and a couple of hose adapters.  I am particularly fond of some small swing check valves that I think Parker made for fuel use; they have a very low cracking pressure.  Most any hydraulic supply house will have all of the fluid components you need.   Find a nice eight-ball gearshift knob to put on the rod to use as a handle.
This of course assumes that you are not dealing with a poisonous or otherwise nasty gas...
Oh.  Finding a way to make one of something without a budget is  very much an engineering problem.
Mike Halloran
Pembroke Pines, FL, USA
You might also try checking out a local ship's chandler or yacht supply. Looking for hand bilge pumps which may be suitable.
I have correct Mike on his post...
Parker don't make things, they buy the companies that make things and they screw them up.
Apart from that...good post, well done Mike!
