Pitting Corrosion
Pitting Corrosion
Hi. i just wanted to get an explanation on why is the 7.5 % HCL worse in terms of pitting corrosion compared to 10% HCL
RE: Pitting Corrosion
It's not easy to give you a reply with so many data. Corrosion is dependent on many factors. It will be necesasry to know what type of material are you concerned about, operating Temperature, environment, fluid and so on to tell something.
Vict
Corrosion & Materials Engineer
http://xoomer.alice.it/corrosion
regards
Vitt
http://corrosionist.blogspot.com
Unless there are factors such as impurities and/or temperature I would suspect that it may be related to minor differences in the materials.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
Vitt
