Proper Nomenclature?
I'm looking for the industry name for the plastic button that is snapped into the webbing of a seatbelt to limit the adjustment or travel of the tension fitting.
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of Eng-Tips Forums?
RE: Proper Nomenclature?
I just had to give you a star for that one. upsidedown
Thank you Greg!  I guess not "everyone" knew that term.
Patents... yes, that seems to be all I can find.  I'm looking for a supplier, only about 3,500-4,000 annual useage.  Any leads?
Considered making your own?  It's not a safety item, so I would think a couple of discs of plastic and a pop rivet gun would work for such a low volume... that's the manual labor of installing 20/day, 5 days a week.  Though appearance may be an issue for you...
Dan - Owner
http://www.Hi-TecDesigns.com
