Calculating Pedestal Stiffness and Shaft Critical
In thread384-156111: Calculating natural frequency of a shaft some one said that a bump test could be used to calculate pedestal stiffness.  Can some briefly explain to me how to do this?  I know how to perform a bump test to get the resonant frequencies, but what do you do with the results to get a value for stiffness?  If I have FEA at my disposal should I use frequency analysis or some other analysis (if a stiffness value is the goal)?
Does anyone have any books the I can reference on this topic (shaft critical, pedestal stiffness or rotor dynamics in general)?
RE: Calculating Pedestal Stiffness and Shaft Critical
If you have FEA just do a static run with a force of 1N applied in the direction and at the point of interest.
Estimating the static stiffness in a hammer test is easy - integrate your acceleration/force transfer function twice in the frequency domain, so give you compliance. Then invert it, and you have stiffness.
If you are reasonably lucky there will be a near horizontal line down near 0 Hz, that is a good estimate of the static stiffness. If you have rigid body modes that'll mess things up, you may be able to convince yourself that a flat line just above them is usable.
Cheers
Greg Locock
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
