flange boltup
flange boltup
Have found references to bolt/stud lengths for ASME B16.5 flanges. What of B16.47 Series A & B. Weldbend.com have suggested method of calculation for length of bolts & studs for flanges up to 24" dia. What about up to 60" for MS SP44 and API 5 (B16.47 series A & B)
Help Anyone?
Help Anyone?
RE: flange boltup
1/4"+Nut Height+Flange Thickness (including facing for RF flanges)+gasket thickness+Flange Thickness+Nut Height+1/4"
For confined type joints you need to determine the gap between the flange edges per the facing configurations and gasket thickness and add this instead of the gasket thickness.
Mike
RE: flange boltup
If you are bolting up to a valve make sure you check the flange thickness on the vlave.
http://www.pacificflange.com/catalog.html
RE: flange boltup
RE: flange boltup
RE: flange boltup
K.J. Beer Pty Ltd: http://www.kjbeer.com.au/
very nice Utilities calculator:
Pipe Deimesion
Flange Rating
B16.5 flanges
B16.47 Flanges
AS 1210
Thank you
Leonard Stephen Thill
L S THILL
RE: flange boltup
You may also need to add an additional one nut height to allow for bolt tensioning equipment - which is normally used on studs 1.35" and above
Your client will advise
RE: flange boltup
You may also need to add an additional one nut height to allow for bolt tensioning equipment - which is normally used on studs 1.25" and above
