Excel files in SE then to dxf/dwg...
Here at work we create tables in Excel, then copy & paste into the SE sheet and it all works nicely. We've got a cusomter who wants the SE file saved as a DXF and DWG, which is easy enough. However, as I expected, the Excel bit does not export... is there a way around it that anyone can think of?
Cheers,
M
Cheers,
M
RE: Excel files in SE then to dxf/dwg...
so you want to have the information in your excel file updated in your drawing (as a table) and then dxf the lot?
M
